Re: L1P CR123 tube with resistor ?
Sure there is a Cr123 tube for the Fenix L1P and even a Cr2 tube but no resistor in the battery tube??? :huh2: It`s easy to add a resistor to the L1P switch for two levels of light if that is what you where meaning. I can`t recall the name of the member that made the two battery tubes right now.
If someone else doesn`t post his name soon I will rack my brain to remember and post it here for you.
Might as well start racking my brain now, I guess???
Ken
EDIT: The
is helping because now I know what you were meaning by the resistor.
I put a different driver in the L1p`s and used Rcr2 and Rcr123 Li-on batteries. I have a battery tube if you want one?
You would have to change the driver or I believe it would just goup in smoke with the higher voltage.
