lv6l said:i was wondering can i use 3.7v or 3.0v cr123a rechargeable lithium for the P1d-CE. and would it run safe? anyone tried this yet? thanks.
I cant help but wonder WHY this happens to the P1D, what is it about the RCR123 that causes that ?gadgetnerd said:Hi lv6l
There are numerous threads on this topic. But to save you searching, the short answer is...
The P1D-CE works fine with 3.7V RCR123s, but initially there is very little brightness difference between high medium and low, until the battery runs down a bit.
On 3V rechargeables the modes are the same as with 3V primary CR123s.
As for "will it run safe?" - there are also numerous threads on the safety aspects of protected vs unprotected RCR123s.
Enjoy your torch!
bridgman said:I think the issue is that a fully charged RCR123 has a higher voltage than the regulator in the P1D is designed to handle. Once the voltage drops to 3.7-odd volts (a fully charged 3.7V LiIon is 4.1-ish volts) everything works fine.
Apparently you get the same behaviour with an L1D-CE if you put a fully charged 14500 cell (also 4.1-ish volts fully charged).
lv6l said:so i check my charger and it says output is 4.2v. does this mean when i put either batteries; 3.0v or 3.7v, the charger will charge those batteries to 4.2v? IF SO can i find/use a charger that outputs at 3.0v or 3.7v and it will be more accurate?
thanks.
