Silviron
Peter- Are you sure that all your battery holders are the same alloy?
The reason that I ask this, is that when I was welding the threaded sections of your LS battery holders to my fabricated battery holders for JonSidneyB's C & D cell holders, I noticed that the 123 holder SEEMED to have a significantly lower melting point than the Single AA battery holder.
The reason that I mention this is because it MIGHT have some bearing on the QC difficulties (and different colors) that you seem to be having on the single AA holders.
Since different Al alloys can have a significant effect on anodizing results, I thought that maybe the single AA holders might have a higher iron, nickel or manganese (or something) content, hence the higher melting point and perhaps resulting in your anodizing problems.
I only welded with the 123 and single AA holder, so I can't say if the double AA holder would have exhibited similar characteristics to the 123 OR the single AA holder.
Just a thought, and I hope it helps.....
