WNG
Hi folks!
Need to ask those who have experimented with 5mm UV LEDs about their effects on typical black plastic of a car's dashboard.
Noticed I had a bulb burn out in my Honda's instrument panel.
It's lit from behind by incan mini bulbs and the gauges glow a cyan color.
But the needles, and some lettering aren't backlit. These are illuminated by 2 front-mounted dim incans filtered to provide white light.
Since I must rip apart the dash to replace said bad bulb....
I might as well replace all of them with white LEDs in one shot.
But what I would like to try, is use UV LEDs to substitute the front bulbs.
The needles and lettering are white, I'd like to get them to glow like white when exposed to black-light.
What I'd like to know is if UV LEDs can provide this, and if it's safe for parts and people....the UV LEDs will be mounted behind a clear plastic panel.
LEDShoppe.com sells UV LEDs, typical of what I may use.
TIA!!
TIA!!
