KingGlamis
Banned
My first attempt at home-modding a flashlight may be different than most, but I like to try off-the-wall things, so please bear with me. The light I want to mod is a DeWalt 18V work light, shown below.
The 18V rechargeable battery powers tools like drills and saws, so it should handle a decent amount of amp-draw (I searched Google and could not find any specs on this battery, other than being 18V).
The light already comes with a metal reflector, so I think all I really need to deal with the heat of a better bulb is a glass lens and probably an internal heat sink. Depending on the amp-draw of the bulb, I may need to upgrade the switch too (not sure yet).
For those curious, I am not interested in any LED options at this point. Yes, I saw the thread with the 18V LED monster light that is very, very bright. For this project I want to stay with incan.
So here is where I am at and a series of questions I have:
I haven't had any luck finding a good 18V bulb. I searched a bunch, maybe I am searching in the wrong places? Anyone have a link?
I did find a Halogen bulb at Fry's Electronics that is 12V and 50W. Might be a good (and cheap at $2.99) starting point. My first question with this bulb is can it be overdriven to 18V at all, and if so, will the life-span be vastly shorter? I took a regular automotive 12V brake light bulb and drove it on 18V, it was really bright for about 10 seconds, then .
If I can't overdrive it to 18V, can I just put an inline resistor to bring the voltage down to 12-13V? I would think that would work as long as the resistor can handle the 4.2amps.
This halogen bulb is the bi-pin type, with a 6.35mm spread. Does anyone know of a bi-pin bulb holder that is available? I looked at Fry's and at Radio Shack with no luck. Any links? I'm also willing to cannibolize something if anyone knows what kind of light originally used these types of bulbs.
Anyone know of any BETTER bulbs that will work on 18V and not cost a fortune? Don't have to be bi-pin, in fact I would prefer it if they were not bi-pin.
Thanks for any help you can provide.
