Main question:
Also! The Fenix P2D CE light output reading, reads, General Mode: 9 lumens (30hrs) -> 40 lumens (5.5hrs) -> 80 lumens (2hrs) -> SOS
Turbo Mode: 135 lumens (1hrs) -> Strobe. I'm ASSUMING the SOS/STROBE next to the readings mean that at this brightness it will flash S.O.S. or it will strobe, in other words a fenix p2d ce does not have a constant on brightness of 80+ lumens. This will eliminate the 2d for me, I just want a constant on, no flashing at high lumens.
I'm new to the forum; I have always had the flashlight bug, and just didn't know there was a forum for people like me! Love this place. To my problem, I'm looking to pick up an LED flashlight. The Three I'm looking at are the Inova T1, Fenix P2D CE, and now the Fenix P1 CE. I realize they are all a bit different, I would just like some feed back on them, which would you get? Why? What do you like about ___?
Thank you in advance! Sorry for the long questions.
O, I currently own these flashlights if anyone cares: Surefire 9P, Surefire x200B(weapon light), Tikka myo xp, and Brinkmann MaxFire LX.
I'm not sure exactly what you are saying or asking, but the P2D will put out 80 lumens under regulation constantly until the battery drains to below regulation.
In addition to that it also has a strobe and high-output in the high mode and it has an SOS mode and a low and medium output in "normal" mode. So, yes, it does have a constant output above 80 lumens -- as long as your battery is relatively fresh you can run it at the turbo mode.
It sounds as though you are confused at how the specs read out. Here it is, reformatted:
Regular mode, low: 9 lumens for 30 hours
Regular mode, medium: 40 lumens for 5.5 hours
Regular mode, high: 80 lumens for 2 hours
Regular mode, SOS: blinks in morse code, unknown output
Turbo mode, turbo:
up to 135 lumens for
up to one hour
Turbo mode, strobe: strobes at full power.
As you can see, 80 -> SOS does NOT mean it blinks at 80 lumens, it means 80 lumens is one mode and SOS is another mode. The same goes for Turbo -> Strobe. That means there are two seperate modes.
You don't state what the usage will be. The P2D is one of the most versatile lights because it is small; bright; has numerous output levels; has longish life; is somewhat durable; has no filament to break; has good color. Beside that you can't expect to use a single-cell 3 inch light to throw out 135 lumens for over an hour. Get a bigger light if you want higher output for longer.
