Copied Replies:
Manzerick08-08-2007 12:20 PM
Re: arc aaa rebel
Sounds like a job for Miller mods!!!
Gransee08-08-2007 03:53 PM
Re: arc aaa rebel
It is too soon to say, but I have something else planned for the Arc-AAA. It won't be everyone expects but it will should be consistant with past decisions.
peter
Daniel_sk08-08-2007 04:00 PM
Re: arc aaa rebel
Wow, exciting news
. Any chance we will see the new version before Christmas? (or maybe already in a month?
Gransee08-08-2007 04:01 PM
Re: arc aaa rebel
Too soon to say. Sorry.
peter
9volt08-08-2007 04:13 PM
Re: arc aaa rebel
Arc AAA-D(raco)?
Russianesq08-08-2007 09:11 PM
Re: arc aaa rebel
oh say it....... or at least give us a hint :thinking:
greenLED08-08-2007 10:01 PM
Re: arc aaa rebel
Quote:
Originally Posted by
Gransee (Post 2052444)
You guys should look up Peter's design requirements for the ArcAAA before getting all excited about a "power" AAA.
270winchester08-08-2007 10:21 PM
Re: arc aaa rebel
peter
:wave:
but Peter, :thumbsdow for keeping your lips so tight, :nana:
Grumpy08-08-2007 10:46 PM
Re: arc aaa rebel
I would like to have one. One level of light is plenty for my uses. Would like approx 5 hour runtime.
Two levels of light would be the maximum that I would like. I purchased two Jetu and could only get them to turn on at the level of light that I wanted about 50% of the time (even less with wet hands while fishing).
I hate to twist, twist, twist,twist, twist, twist,twist, twist, twist,twist, twist, twist!
Gransee08-09-2007 06:55 AM
Re: arc aaa rebel
greenLED (Post 2052553)
Heeee's right.
peter
Manzerick08-09-2007 08:15 AM
Re: arc aaa rebel
Exaclty! My arc is not a blaster nor should it be!
I'd take a "miser" type Arc with serious runtimem and a hair brighter. The buid quality is such that it is well, well worth it IMHO!!
Gransee (Post 2052654)
Heeee's right.
peter
Manzerick08-09-2007 08:18 AM
Re: arc aaa rebel
From the ARC site:
Arc-AAA
Purpose: The Arc-AAA is designed to meet the qualifications of the "Every Day Carry - most convenient" class. To meet these goals, the light must:
Be small enough to be carried with minimum effort and thought. Ideally, it would attach to something else you already are in the habit of carrying. That way, it is more likely to be with you during an emergency
Have sufficient runtime to last the length of typical emergencies with an additional amount added because we can assume the battery is not always fresh when you leave the house
Use a common battery that can be found throughout the world and can also be scavenged from other equipment
Be durable enough that it can be depended on over a wide type of emergencies including floods, fire, earthquake, etc. It should be at least as durable as the person carrying it
datiLED08-09-2007 08:25 AM
Re: arc aaa rebel
A Q5 CREE, powered at 150mA. It would only require a minor revision to the circuit board, and would run for a respectable amount of time with a white floody beam. Heat would not be an issue. And while it won't light up the side of the house, it will be significantly brighter than the AAA-P.
Am I close?
THE_dAY08-09-2007 08:40 AM
Re: arc aaa rebel
my guess is a different colored cpf special version..
but my dream is a cree Q5, please no more angry blue LEDs
Daniel_sk08-09-2007 08:47 AM
Re: arc aaa rebel
Yes, I am also not looking for more output (or maybe only a little more, if it doesn't compromise runtime), rather I would like something that hasn't got the angry blue tint and is more efficient (more runtime, same or little higher output)...
Gransee08-09-2007 08:56 AM
Re: arc aaa rebel
I probably shouldn't be showing you guys this. Its probably like adding gas to a fire... Always with the pestering about using a larger LED. geez.
And no, I am not making this flashlight. Just showing that I do research stuff occasionally instead of spending all my time on the forums telling you no.
Don made this head. It has a Seoul 1/2 watt driven with the stock pcb (5hr runtime). This picture was taken back in March. It was tested in the sphere and produced about 10 lumens. Beam is nice and tightly focused (it better be with that huge planet sized head) and the tint is very nice.
Nope, I have something else planned. And just to set your expectations down a notch, I did this while working on a big, huge, all-consuming project (the LS) and so don't expect that the new AAA is also a big huge development as well. Tiny steps.
peter
THE_dAY08-09-2007 09:05 AM
Re: arc aaa rebel
tiny steps are good as long as their in the right direction
Daniel_sk08-09-2007 09:13 AM
Re: arc aaa rebel
For me, Arc AAA looks is only a little (LED) step from being perfect
Manzerick08-09-2007 12:27 PM
Re: arc aaa rebel
Thank you Peter!!! Very nice proto!!
The Arc with the big head should be called "The Barry Bonds"
:lolsign:
Daekar08-09-2007 02:48 PM
Re: arc aaa rebel
Heeee's right.
peter
Heheh glad to hear it. Somebody has to keep making sensible lights! In actuality, unless the emitter is going to be changed for a more efficient one... I can't really think of a way to improve the AAA-P. It's pretty perfect the way it is IMHO. I'll be curious to see what you come up with though. Oh yes, those pictures and all the discussion (and your responses) about the LS have me dribbling with anticipation. I hope they're not out of my price range, otherwise I might have to start selling off things to get one.
smknman08-09-2007 03:29 PM
Re: arc aaa rebel
All i'm looking for is a white tint and maybe even more runtime. 10 lumens are plenty. Kinda surprised to get a response, especially one that gives me hope.
WTH08-09-2007 03:31 PM
Re: arc aaa rebel
Look at the waiting list for millermods arc-aaa's. Maybe you should just put something like that into production and call it a day?
>08-09-2007 04:00 PM
Re: arc aaa rebel
I am glad to hear that the wheels are turning for the improved Arc AAA. I believe that the only possible improvements are to make it longer running at the same output level and get a whiter tint from the emitter.
I wouldn't even want to see the regulation change.
BytorJr08-09-2007 07:25 PM
Re: arc aaa rebel
10-12 lumens sounds good, with a little more throw. Not much, just a little more. Kind of like my Solitare with the drop-in. It throws good but has a good amount of spill. Nice White light on the warmer side and say 10 hours of run time (if that's conceivable). I'd like to think if I was trapped somewhere in a disaster I'd have the ability to have a light for a while to keep me from having a claustrophobic attack.
Possibly even a low mode of 2 lumens with some outrageous run-time even if not continuous would even be better, but not a requirement in my book.
Sinjz08-09-2007 07:42 PM
Re: arc aaa rebel
Can't wait to see what you came up with and if it's good enough to make me replace the original Arc AAA I still EDC.
skalomax08-09-2007 08:01 PM
Re: arc aaa rebel
Very cool.
but, brighter is better. Muahhha
Radio08-09-2007 08:26 PM
Re: arc aaa rebel
RunTime!!!!!!! I want a Survival Light! I have bright lights, I want a light that will run FOREVER!!!!! :thumbsup:
fluke08-09-2007 09:16 PM
Re: arc aaa rebel
Brighter ??? No.
Whiter ??? Yes please.
Runtime ??? More is better , but 5 hours plus is superb.
Does anyone really want to change this little masterpiece ???
It's a classic that many have tried to imitate.
I love my Arc AAA P, wouldn't want it changed drastically, but a less blue LED would be nice, you all just have to trust in the maker
BytorJr08-09-2007 09:33 PM
Re: arc aaa rebel
Brighter is NOT better in this case, well significantly brighter anyway. Like I said, 10 lumens, a tiny bit more throw. I want something where if I'm stranded and trapped I have light for a LONG time. With an ultraefficient LED, I would think 10 lumens for even 5-7 hours is possible. An EDC light should have sufficient run time to get you out of the jam you may be in. Imagine being stuck in the Amazon - 10 Lumens would be tons of light, and then you'd favor more throw and insane run-times.
Just my 0.02.
DarthLumen08-10-2007 09:42 AM
Re: arc aaa rebel
BytorJr (Post 2052903)
Just my 0.02.
Peter,
I concur...with a slight increase in lumens and maintain or increase similar runtime, this light would be all one could ask for...well at least for now. L.O.L.
Most importantly, as a few members have mentioned, it would be great to replace the LED with one that is white. (let's phase the blue out)
Simply give me decent light and long runtime.
We're drooling here.....let's get that new AAA on the market and let the madness commence!!!!!!
Marduke08-10-2007 10:06 AM
Re: arc aaa rebel
How about a red LED to preserve night vision? And runtime would probably be even longer...
speederino08-10-2007 03:29 PM
Re: arc aaa rebel
Bring back the Arc-AA. Please!
skalomax08-10-2007 10:52 PM
Re: arc aaa rebel
"Floodiness" Is the key imho.
The styling and finish is great, just a tad brighter and a more flood type beam.
10-15lm?
I don't think keychain lights are supposed to throw. :green:
BT13243508-11-2007 12:11 AM
Re: arc aaa rebel
Maybe a two-stage arc AAA huh? 3 lumens + 10 lumens
MacTech08-11-2007 02:23 PM
Re: arc aaa rebel
the only changes i'd like to see, as has been stated upthread, would be a longer runtime in regulation (8-10 hours or so) and a cleaner tint, less "angry blue", if this can be done with a standard 5mm LED, great, as they have a durability edge over the "Power LED" type
keep everything else the same, beam pattern (floody) and the head-to-body ratio (that "Turbohead" AAA pic looks too unnatural to me), maybe take a page from Peak and have a threaded tailcap with a screw-on lug, so the AAA could tailstand for ceiling bounce, but only do this if it doesn't compromise durability/add unneccecary length
TurboDog608-12-2007 11:08 AM
Re: arc aaa rebel
Another vote for the Arc AA!
Manzerick08-12-2007 11:50 AM
Re: arc aaa rebel
a new Arc AA would be nice!
sawlight08-12-2007 05:03 PM
Re: arc aaa rebel
BytorJr (Post 2052840)
What I have been BEGGING for for quite some time now!!! I can buy lights that have more power than battery anywhere now!!! K I S S!!!! One stage 10ish lumens 10ish hours runtime, maybe a second stage, but not necessary, just go to moon mode and let it drop slowly!!!
glockboy08-12-2007 06:04 PM
Re: arc aaa rebel
I like the Arc AAA Cree R5.
:thumbsup:
