The fact that I'm italian doesn't help me... what's the difference between "headlamps", "flashlights" and "headlight"?
I'm confused.. :thinking:
A headlamp is a flashlight that is designed to be worn on your head, for when you need to keep your hands free.
A flashlight can be defined as a portable light source with an autonomous power source, meaning it isn't plugged in while being used.
A headlight is a part of an automobile, and is used to illuminate the roadway.
Thanks Greenlead for the explaination. I forgot one: what's a leadlight?
Leadlight is another word for stained-glass, used in church windows and tiffany lampshades.
The bits of glass are edged with lead.
Which we call a "cage lamp" in Australia.In the UK a Leadlight is a light that a mechanic might use under a car, it normally runs on mains, plugged in, via a Lead (Cable)
In the UK a Leadlight is a light that a mechanic might use under a car, it normally runs on mains, plugged in, via a Lead (Cable).
Joe.
Your English is much much better than my Italian.
Never worry about asking a question about ''english" usage. Here at least. I would hope we would all be polite.
Lead and Lead and Lead is a perfect example of the difficulty of english.
"Lead , follow or get out of the way"
"Lead in paint caused the brain damage of children"
Context means a lot. If your car was in an accident it would be the headlights that would be damaged. If you were running a nighttime race and bumped your head on a branch of a tree then your headlight would be damaged. ---- See ?... easy ?...LOL
