Modifying a Dorcy Headlamp
ljsmith
Hi,
I am new here. I have been reading on the forums, but now I have a question. I have a Dorcy 3 watt headlamp that uses a luxeon III. It is powered by 3 aaa batteries. This light appears to have no regulation, and eats batteries really fast. I would like to hook up a larger battery pack with four AA batteries. I also would like to use a higher power led like a P4. I want to use some type of regulation, but I don't know what I should be using. I saw these regulated boards: http://www.dealextreme.com/details.dx/sku.3256 but I wasn't sure if this is what I need or not. If it is how do I hook it up? I see that there are output wires to the led coming off the board, but where do the input wires go? I am definitely a newbie at this sort of thing, so any help would be greatly appreciated.
-Lance
spider-cricket-hater
hey, welcome to the forum. I am sure lots of folks will help you out here. I suggest posting some pictures of the open Dorcy headlamp, so people would know what you are talking about.
good luck!
ljsmith
This is a pic of the light and the specs.
  • ***** NOW AVAILABLE *****
  • Forever Bulb- Never need to replace th bulb!
  • 65 Lumens of light output
  • Projects over 100 ft. beam of light
  • Contains Luxeon 3 Watt LED
  • Includes 3AAA Energizer batteries
Product Specifications
UPC: 035355420982
Weight: 0.44 lb.
Length: 5.50 in.
Width: 3.63 in.
Height: 8.13 in.
