A newbie hello and question
magirus
Hello to all on the forum.I've lurked a while, and now have a question. I have 2 Fenix lights, an L1DCE and a P2D Rebel100. The heads are interchangable, so when I use the P2D head with the L1D body what will be the resultant run times and output (in lumens). The output looked the same during a quick changeover, but I suspect things can't be that simple.My naive guess is that the output is the same with reduced runtimes.Thanks in advance, MAGIRUS.
Gaffle
Garden City, MI
Ask, and thou shall RECIEVE!! *wonderful orchestra plays*
*Angels sing* "Click hearrrrrrrrrrrrrrrrRRrrRRrrRRR!"
As to the lumen amount, dunno. Selfbuilt has a lux reading. You can probably find a P2D RB100 review with a lux reading to compare the two.
Actually, why I just pulled one out of my hat. *poof*
The second link has a P2D RB100 lux readings, but the readings are with a RCR123. I don't know if that makes a difference or not.
Gunner12
Bay Area, CA
The heads actually have the same circuit except with a different LED. You would get more output with the P2D body(3V battery vs 1.5V)
The of the P2D, L1D, L2D, L1T V2.0, L2T V2.0 are all interchangeable.
:welcome:
magirus
Thanks for the info gents.The links to the reviews/tests by selfbuilt were particularly helpful.
