Re: SF E1L Dual Output
Ok, I have the light in my hands.
First when you press the tailcap it goes to LOW output first then HIGH output.
Quoting from the manual:
RESET FEATURE:
The Surefire E1L and E2L are equipped with a switch reset feature. If the tailcap pushbutton switch remains in the off position for longer than two seconds, it is programmed to activate the low-output beam the next time the switch is pressed. This feature is automatically activated when the flashlight is turned off from either the momentary-on or constant-on mode.
MOMENTARY-ON:
For momentary-on low output beam, partially depress the tailcap pushbutton switch.
For momentary-on high output beam, first partially depress the tailcap switch for momentary on low output beam (per above). From this position, release the pushbutton switch, returning it to the off position, and then partially depress the switch again within two seconds.
CONSTANT-ON:
For constant-on low-output beam, fully depress the tailcap pushbutton switch until it clicks on.
For constant-on high output beam, first click the tailcap pushbutton switch to constant-on low-output - or momentary on low-output (per above). From this position, click the flashlight off and back on again within two seconds.
