tebore
When used with 17670 cells with the stock spring or 18650 using a modified spring a fault can be found. Have your light in a fully installed and ready to use state. Turn on your HDS then holding your light by the head section and the tail(battery) section facing up (between your index finger and thumb) swing the light. You will notice your HDS turn off and then flash back up to the last lit up state(indicating an error) you will loose button operation as well.
I have been unable to reproduce this using 2x123s but using any single cell it has been reproduced on all 3 of my tubes and all 4 of my HDS lights.
Henry if you see this it's something to consider in your design of the Ra Twisty's battery tube.
Seems like the forces acting on the battery is too much for the spring.
