Hello, I'm new here but have been reading quite a bit on this forum. I have learned a lot and appreciate it. Recently I have been getting very interested in Surefire lights. Pardon me if the answers to these questions are obvious to everyone:
1. What makes the L1 cost more than the E1B?
2. Does the E2DL have 2 light levels? If so, why does the new catalog not mention that fact? And also, why would they not name it L2D?
3. Once the UA2 is available, would there be any point buying an L2, other than price?
Thanks and regards,
Allan
Welcome to CPF Allan!
Firstly, SureFire's pricing structure and product range may be better understood when viewed from the perspective of how the product range has evolved over time. Some things may be simply because they have been historically.
The L1 features SureFire proprietary patented two-stage push button pressure switch user interface to seamlessly transition between levels based on how hard the switch is pressed. This user interface (UI) is both electrical and mechanical in that it requires specialised engineering and materials as well as electronics. There is a lot going on under the hood of the L1.
The E1B (like the E1L) is more straight forward - in fact the dual output nature is purely electronic - SureFire are able to configure this by adjusting the settings of electronics in the bezel.
As mentioned SureFire's 2008 catalogs were published prior to SHOT Show 2008 where many of their new products were first shown. It is normal for things to change as SureFire makes the products ready for market release.
Important details of the UB2 in the catalog are incorrect as well. We'll see how long it takes for actual photos of the UB2 to be discovered by CPF members.
You would think they would - it would be less of a mouthful than 'E2DL'...
But the E2DL is an evolution from the E2D (as another member mentioned). It is an LED version of the E2D. It uses the same body and TailCap. These are very different to the L2's body and TailCap (slimmer for a start).
An "L2D" would feature two-stage push button pressure switch technology.
SureFire have released an L2D of sorts - its a limited edition model called a Porcupine (L2-PP). In fact they've released two versions of this.
Perhaps they'll release an L1D though? I don't know. It's more difficult to do a Stainless Steel "Porcupine" version with the new L1 bezel design...
As technology marches on some products will phase out of the range. The L2 could well be one of these.
However, I don't think it'll be superseded by the UA2.
As my photo from SHOT Show 2008 shows:
The UA2 is longer than the L2 - some would say that the L2 is already far too long.
The UA2 is fatter and heavier than the L2. This makes it in a different class of flashlight.
I think that people who currently carry the L2 may look at replacing it with a UB2 (or perhaps a UA2). I think UB2 is more likely.
The UB2/UA2's bezel down pocketclip and the length of the L2 body make them stable for carry (when the bezel is too long [compared to the body] it can make carrying the flashlight bezel-up less ideal)
Does this help answer any of you questions?
Al
