Re: You guys are going to get me in so much troubl
firestarter,
Before you go off and buy another 2 cell incandecant nearly identical to your Scorpion, I have some other suggestions that you may find usefull. First, I will say that I bought a G2/P61 a while back (Before the price was reduced from 50 to 35 dollars), and while I can say that the 120 lumens do provide a significant "Wow factor," the utility of this feature does not lean toward general usage. Of coarse, if you intend to use your G2 for self defense, that is another matter. Overall, however, I do not find the decreased runtime worthwhile during normal use.
Secondly, I will echo the sentiments of others here by suggesting a multi-LED or luxeon flashlight. While Incandecants rule the outdoors, many times LEDs more than suffice indoors and in areas with little or no ambient lighting. As you allready have an E2 on the way, you could go the KL1 route. An inretech dropin may also fill the niche, and for 20 dollars less.
Finally, there will eventually come a day when you find yourself in need of a headlamp. There are many to choose from, however I only have experience with the Princeton Tech Aurora. I believe it to be a sound investment for around 25-30 dollars.
In any case, good luck with your purchases and do not hesitate to ask questions.
Respectfully,
Dale
