I just got a FiveMega 9AA carrier for my Mag85 build. I'm using Eneloop batteries. When I first assembled the battery carrier with the batteries (about 4 days ago), everything seemed to go fine. I took the battery carrier out tonight to connect the charger wires to the supplied male plug. The battery carrier was sitting for maybe 2-3 minutes, on its own, separate from everything else.
When I went back to grab it, it was extremely hot. I quickly took it apart and let it cool. Now when I go to reassemble it, I stack all the batteries in the carrier - no problem. But then when I go to screw the positive end of the carrier in, it sparks between the brass and aluminum and starts getting hot again in a hurry.
What did I mess up or what is messed up that's allowing current to run through the carrier when it's sitting on the table?
I've checked and double checked to make sure the batteries are facing the right direction. It seems like something's making contact that shouldn't be????
oo:
oo:
