SSC caused a lot of confusion and arguments (especially between phantom23 and myself) as they keep changing the specs of the SSC P7
Old spec
B-bin 5xx to 740 lumens @ 2.8A
C bin 740-900 lumens @ 2.8A
New spec
C bin 700-800 lumens @ 2.8A
D bin 800-1100 lumens @ 2.8A
SSC is shipping new spec LEDs as D bins are now available from photonFanatic.
http://www.cpfmarketplace.com/mp/showthread.php?t=182492
But old spec B bins are still available
http://www.dealextreme.com/details.dx/sku.11809
and if you see C bin there is no clue if it is old spec or new spec.
Old spec
1) Some optimistic flashlight manufacturers simply use the biggest # they see - 900 lumens.
2) Wolf-eyes figure their lights are only running at 2.1-2.2A and not all P7s are 900 lumens so de-rate to 580 lumens at the LED.
3) Surefire gives #s for light out the front (as measured, not guessed) and only claim 400 lumens for the UB2.
BTW
fire-stick there is something wrong with your latest thread (will there be a 3xSSC-P7?).
1) The smallest reflector that will work with a P7 seem to be 27mm. 3 of them won't fit into a M@glite head.
2) The M@glite switch can only handle 5 or 6A. 3xP7 in parallel requires 8.4A plus a safety reserve.
3) 3xP7 in series requires 10.8V such as 9x C or D batteries. The biggest M@glite is 6 cell.
It is possible for some custom 3xP7 lights to be built, but I would not expect production lights.
That being said a 4xP7 light is available from Elektrolumens run in 2S2P configuration. 6D NiMH or 2D Li-on.
Elektrolumens Wall-of-Fire.
http://www.cpfmarketplace.com/mp/showthread.php?t=179644
