Been doing a lot of searching and reading and have come up with a list of under $30 flashlights with the sole responsibility of glovebox duty. I'm posting my thoughts/research here if someelse is in the same position. Any comments and suggestions are welcome.
Glovebox duty criteria:
1. Generally housed in glovebox, will only see use occasionally.
2. Need to use lithiums for long shelf life
3. Needs long throw ability
4. Needs to be economical, and in my case I'm setting the absolute ceiling to $30, gotta draw a line somewhere
5. Needs to be of reasonable size; large enough to be comfortably handheld, small enough for the glovebox
6. Aesthetics are not too important
7. Battery life is not too important. I've rarely had to use a flashlight for more then 15 minutes at a time. One set of spares will be carried. I'll always have an LED light on my keychain for long life purposes.
8. Adjustable beam is a plus, since map reading and sign spotting are two possible uses.
Batteries:
Lithium is a must. Having said that, 4 AA's will cost me roughly 30% more then 2 123's. (Correction, 4 lithium AA's $10 will cost me quite a bit more then 2 123's $3) AA's in general are easier to obtain though, so no advantage either way.
Candidates:
1. Streamlight Scorpion ($23 + ship)
Leading contender. Metal construction, adjustable beam, clickie tail switch, and built in spare bulb. Rubber coating can be considered good or bad. Limited bulb life, not too thrilled on changing bulbs.
2. SureFire G2 ($25 + ship)
Not going to buy a light based on brand name, but this is still a good light. Well constructed, good beam. I'm not a fan of twist switches, no lockout tailcap, and expensive replacement bulb.
3. Brinkmann LX ($20 + tax)
Fit and finish may not be up to par to the two above lights. Adjustable beam (I think), metal construction, and clickie tailswitch. A few dollars cheaper then the above lights.
4. UK2L ($24 + ship)
Plastic housing with weaker light output with extended run time. Bezel twist switch.
5. Princeton Tec Surge ($22 + ship)
Good bright waterproof AA light, can't use lithiums. Side lever switch.
6. Princeton Tec 40 ($13 + ship)
Economical, waterproof and lithium compatible. Many LED mods available. Bezel twist switch.
7. M*glight 2D ($20 + tax)
Aluminum D cell flashlight. Weaker light output with excellent run time. Lithiums not available. Potential use for self defense.
8. Streamlight Tasklights ($20-$30 + ship)
Not out yet, looking forward to these.
Added from comments below:
9. Pelican Stealthlight ($20-$25)
Stealthlights seem to have a good reputation for durability, have a long throw beam, but the beam is narrow and not adjustable. I haven't kept the light on for a long period of time, but so far with momentary use I haven't seen a problem with using lithiums.
10. UK 4AA ($16 + ship)
Same output as UK2L. 4-5 hour runtime on lithium AAs. Nicely designed "clickie" switch on newest model (AS2). Tough ABS body with rubber bezel. Hazardous location rated.
Anything I miss? Please keep suggestions to under $30.
Updated with some of the great comments below.
Batteries:
Candidates:
