Peter1976
I've just decided to buy a Pila flashlight. After been reading about the Pila I have some doubts concering their tactical button. It seems that it's very hard to now when you go from momentary to constant on. I have heard people say that they really didnt notice when they pushed it far enough to go from momentary to constant light.
This might not concern most people, but in my line of work, as a police officer, you can't really afford to do that mistake. I don't wanna end up in a crucial situation and the damn flashliht won't go off cause I accidently pushed it to constant on.
The first thing that happens when you get your adrenalin working is that you lose control of you finer motions. That makes it even harder to know when you go to always on.
Do any of you know if you can buy another clickie for the G2R or G3R, with more feel?
I know that on Pila GL models (with the LED) you must rotate the bezel to put it on constant light. I might need to buy a more expensive GL model and order an extra clicke and use that instead of the LED. But that doesn't seem to be a good option, cause I don't need the LED.
You might suggest that I should buy another flashlight than Pila, but I really like that they have a wider spread on the beam. Very useful.
And a last question, how do you Pila owners experience the ligth output, after you used it for awhile. For example, if you use the Pila G2R with 80 lumen/50 minutes. How bright is the light after you used it for 20-30 minutes. Is it still 80 lumen you think, or is it more like after 10 minutes 70 lumen, 20 minutes 60 lumen, and when you used it 40 minutes it's just about 20-30 lumen.
I know it's hard to answer in exact lumens, but do you experience the flashlight to drop brightness after you been running it for awhile?
/ubbthreads/images/graemlins/help.gif
