woodbender
I just finished a Legend AA Micropuck mod. I really like this light a lot. I like the compact size along with the tailswitch. I don't know what the run time will be, but this light is going to get used regularly.
The pictures aren't the greatest, but they get the point across. You can see in the second shot the pill inside the body. I had to grind out some areas of the lip for the pill to fit. The screw has a double function by holding the grounding wire along with holding the pill in place when batteries are removed. The beam shots are taken at 3ft. and at 9 1/2 feet.
http://woodbender.freeservers.com/images/assembly.jpg
http://woodbender.freeservers.com/images/led.jpg
http://woodbender.freeservers.com/images/3ft.jpg
http://woodbender.freeservers.com/images/dscn3767.jpg
