Swedpat
I have a question. Regulation means that the regulator adjust the voltage between such a voltage range and the brightness will be the same within that range. But how does this work when it comes to Maglite 2 and 3D?
The TLE-6EXB TerraLUX MiniStar5 provides around 100 lumens with 2D and 140 lumens with 3D. How is that possible? I mean the regulator cannot know how many cells are used in the flashlight. Or? After a while when the voltage of 3 cells will drop to the level of 2 fresh cells the brightness ought to drop to around 100 lumens. Does the regulator have 2 levels so it provides 140 lumens above 3 volts and 100 lumens below that? Or does the regulation work only for 2cells?
Regards, Patric
Regards, Patric
