ASP Sapphire is a big fat Photon-esque keychain light with an integral clip (ie, it`s a 5mm LED/lithium coin batteries/squeeze-to-glow light). Runs on a pair of CR2016 batteries, and
is a factory sealed unit meaning you cannot replace the batteries yourself.
But since it`s not waterproof either, it means you can`t dry it easilly if it gets wet. To me, this is a design flaw on a light that is priced such that it is clearly not meant to be disposable. I expect they`d still honor their battery replacement policy, but there is a chance that they`ll be able to tell it`s gotten wet and charge you a "repair fee".
Which is a bit silly since as far as I know, they crack the case open and chuck it (I`ve tried opening one of mine, as does Craig at the LED Museum, but there doesn`t seem a way to do it without destroying it), and just re-use the LED if it`s re-usable. The light you get back after sending in for new batteries, is likely not to be the same light you sent off to begin with! Might be the same LED, but that`s probably about all.
It`s probably too late by now, but if it happens again, shake as much water out as you can and then leave it on top of your computer monitor (while the monitor is on of course). The warrmth will be enough to dry it out in a few hours. And don`t worry about excessive drain on the cells. The LED in the Sapphire is so efficient at very low powers that it can emit a very visible glow with a current flow of
microamps- in other words, hardly no power at all
I`d add a reccomendation to the Arc AAA too. Nice lights. Very nice lights
