Re: Opalec New Beam worth the $25 ? anything bett
From what I understand, the Madmax modules don't regulate quite as strongly, causing a bit more slop off in light output over time. However, they will have a bit longer runtime, but at low output.
The BadBoy modules regulate more strongly, causing a bit less runtime, but at an almost constaint output level.
The modules typically come in a 400mA and 500mA output, where the larger, the brighter.
I'm not familiar with the Q3, but it looks like it is a special, higher quality LED. I suspect the LED is not brighter, but simply whiter. It looks like this adds about $10 to the price.
So, the MM + Q3 is the normal Madmax module, with a special LED.
I'd recommend a Badboy 500mA, and add Q3 if you want to go whole hawg. Maybe someone else could comment on the Q3.
-john
