Johnnywong:
It's you again! /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
The fast charger does have a red/green indicator light on it to indicate charging/charged, respectively. Charge time w/ the smart charger will usually charge a depleted battery in under 2 hours (based on my own charger time).
The older, overnight charger only has a red light to indicate charging; there is no full charge indicator. As its name suggests, it does take several hours to charge a depleted battery. I am unable to be exact, because there is no charge level present on this charger.
You referred to your 8X ... does this mean you have one? I had thought from your previous thread that you were mulling over the purchase of an 8X.
BTW, it is not recommended that you fully disharge the battery prior to recharging ... I believe that doing so can damage the cells and limit its charge capacity on future chargings. I think this was from the owner instructions; if I am incorrect, anyone feel free to correct it, and I will
/ubbthreads/images/graemlins/twak.gif /ubbthreads/images/graemlins/poke2.gif /ubbthreads/images/graemlins/banghead.gif myself. /ubbthreads/images/graemlins/grin.gif
And as the above posts say, ask away w/ any questions you may have ... this is the place to do it (where you would get a semi reliable answer, anyway /ubbthreads/images/graemlins/smile.gif ). This is where I come to learn about, and when I can, help with, flashlight information.
