Dr Jekell
I am a member on another forum & in a thread about a RCR123A Charger I got this reply:
Could some one help me form a logical reply with information on the different chemistries between CR123A & RCR123A batteries and why it is a bad idea to try to charge a CR123A battery.
Dr Jekell wrote:
Just a FYI:
CR123A - Disposable Lithium Battery
RC123A - Rechargeable Li-Ion Battery
CR123A batteries can explode if you try to charge them.
This is quite possibly the most retarded thing I have ever heard. LI batteries are all the same, it's just that some have two extra connections on the battery pak; one is for monitoring circuit current while charging and one is for monitoring battery temperature while charging. Both of these extra connections need to be fully monitored during each charging cycle before a reasonable person can assume the charged battery pack is adequately safe for use when fully charged.
A LI battery has no more propensity to 'explode' than your average NiMH battery; but when it does leak your LI battery is far more useless and far more expensive to legally dispose of. Coupled with the fact that the manufacturers can make each LI battery so much smaller nobody would care about it, and you have the very direct reason why your local trout stream needs to be stocked every year at taxpayers expense instead of naturally rebounding to it's former glory; a reasonable citizen can understand why lately big business has been gaining political ground over local environmental groups. Don't pretend they have nothing to gain by misleading you.
