spc
Hey guys,
I'm planning on a build that consists of a 2d maglite and the WA 14w ballast. This ballast runs at around 12v (9v-16v to be exact). I would like to run it off 8aa nimh cells but the voltage is a little low to run the ballast near spec. Also would like to run it off 2x imr 26650 cells but same thing- voltage too low.
Is there a driver that I could use to bump the voltage up? When running I believe the ballast uses less than 2 amps. But startup may use 5 amps for less than a second though..
Maybe it would be ok to run 6x aa sized li-ions in a 2x3 parallel configuration giving about 12.6v?
Any ideas appreciated.
Thanks
Thanks
