What blows...
Ginseng
What blows the filament in a light bulb when you push it too hard? Is it overvoltage or overcurrent?
Wilkey
Ginseng
Ok. Overheating from excess voltage or excess current?
shiftd
CA
I think it is both. The overvoltage makes overcurrent as the bulb follows a simple ohm's law V = I * R. But, the overheating is caused by over current as the heat generated by the filament follows equation P = I^2 * R. So, over voltage makes overcurrent and overcurrent makes overheating ==> blows the filament
FalconFX
Davis, CA
The filament can act as a resistor of sorts for only a short while before heat will melt it. You can push in too much current without a high voltage flip, so I'd say your starting point to watch out if you're worried about flashing a bulb is to watch for high voltage...
Ginseng
Thanks Shiftd, FalconFX,
Your explanations were most helpful.
Wilkey
