EricMack
- Joined
- Jan 13, 2004
- Messages
- 1,128
Time to thin the herd, and I ended up with two of these, so one needs a new home. This is an unused light, new in the wrapper, with the excellent Ti Up and Down clip. Specs are as follows, from a users perspective, this is my go-to light.
I'd like $625 >$600 SOLD! shipped priority to your door (International contact me first). PP is fine. "I'll Take It" has priority over PM's.
Titanium body - Built like a tank.
170 lumens, narrower beam for longer throw.
Sapphire lens with anti-reflective coatings, fully shock mounted.
4 preset brightness settings. The brightness settings and the turn-on setting may be customized for special missions.
1.25 hours typical runtime on High setting, one hour minimum.
Constant brightness through constant power regulation
Graceful low battery warning.
Designed for both primary lithium batteries and rechargeable lithium-ion batteries. Protects rechargeable batteries from over-discharge.
Full thermal management.
Potted electronics for the ultimate in reliability under extreme conditions.
Anti-damage battery compartment protects battery under extreme conditions.
Customizations include turn-on setting, momentary operation, automatic shut-off, button lock, locator flash. Output settings can include burst output, tactical strobe, emergency strobe and emergency SOS or any brightness level.
Reverse battery polarity protection without diode power penalty.
Pocket clip, deep carry bezel up, MOLLE compatible, retaining.
Water resistance: 2 atmospheres (20m or 66 feet of water) - static.
Weight: 122g (4.3oz) including battery.
