3C Maglite mod w/ XPG R4 2B tint
Why XPG in a maglite?
Parts
3C Maglite (Black)
Shiningbeam 1.4amp 3mode 4xAMC7135 regulation circuit (2.8v to 6v)
Shingingbeam CREE XP-G R4 2B tint LED
Britelumens C Mag deluxe Heatsink
Used 3xAA Rayovac alkalines for the beamshots.
(Comparison light:2D D bin P7 Mag 8xamc7135 had 3xSub-C NIMH cells.)
Third mag build, here we go.
Opened her up
Removed switch cover.
Unscrewed the sliver barrel and remove switch guts.
Cracked the remove the brown plastic.
Cut the reflector.
The Britelumens heatsink was designed for the SSC P7. Sanded down ridges until it's flat and smooth.
Cleaned heatsink and bottom of LED with isopropyl alcohol.
Cut the metal thingy from the switch and solder wires to it.
Soldered up LED, trying not to fry it with too much heat.
Soldered wires to the circuit.
Classic mistake!! heatsink goes in from top and switch from the bottom of the body, so I had to un-solder assemble, then re-solder switch.
Nice fit! Tight heatsink fit using aluminum foil to take up space.
SHOWDOWN! 2D P7 Mag vs. 3C XPG Maglite
Ambient light in driveway.
3C XPG Mag on LOW 70 mA
3C XPG Mag on MED 420mA
3C XPG Mag on HIGH 1200mA
Somebody tripped the lights on the other side so didn't get a chance to compare P7 and XPG in the yard.
Hallway ambient light
3C XPG R4 Maglite on MAX 1.2amps at tail w/ 3xAA alkalines
2D P7 D bin Mag on Max about 2.5amps at tail.
The AA alkalines measured 1.2amps max at the tail, using sub-C I got 1.4amps. I know alkalines suck with high drain rates but it's good to know they can still be used for emergencies.
I am pretty happy with this project, I will do extended runtime tests for heat tomorrow.:tired:
- Big and sturdy MAG body.
- XPG is cheaper then other multi-die or SST LEDs but very efficient.
- 3c body can accommodate 18650 and other lithium cells with spacers.
- Can run off 3xAA alkalines in a pinch.
Parts
3C Maglite (Black)
Opened her up
Cut the reflector.
