wquiles
I was fortunate to buy one of Mac's awesome Ti hosts from his SST-50 EDC run, but instead of a very bright SST-50, I wanted a lower power option, with a Hi-CRI LED. I already have a few of the very nice 1 watt Nichia 083 that Don used in his Ti beauties, but I found a place in Germany that sells the hight/top bin of the 3 watt Nichia NSL183T-H3, warm white, with a CRI of 85, and a "temp" of 3500K.
Here on top is Mac's Ti host, and below is my Ti host using Don's Ti Clickie Pack, with a Ti XR19 Mule Head, and Don's Nichia 083 High CRI LED:
This new Nichia 3 watt LED, for this top bin, should make a typical of 215 lumens at 700mA @ a typical vf of 3.5V per Nichia's data sheet, and with a max. current rating of 900mA. I since I wanted to drive it from a single CR123 cell LiIon rechargeable cell, I selected the BB Nextgen 750mA, as I did not wanted to drive it too hard.
I first tried soldering the new emiters into Don's boards, but the new emiter has both its positive and negative pads partly inside the plastic body in the bottom, and it shorts out with the center pad. Nichia 083 on the left and Nichia NSL183 on the right:
Mac's design calls for a 17mm dia board/driver, but the BB Nextgen is 0.55" dia, so I had to make a custom spacer to hold the board in position:
Very nice, tight fit:
This was my paper design for the Delrin adapter (not drawn to scale):
Preparing the negative contact wire with my 3-hand helper
I had to file the Delrin spacer a little to clear the screw that Mac provides for a solid GND:
Testing the reflector focus - beautiful:
Created the raised positive contact for the driver:
Solder the driver wire's:
and applied a thin coat of two-part clear epoxy to keep everything in place:
Here are the two hosts:
How does the new hi-cri emiter looks? Amazing. Here on top if my new Ti host with the NS6L183 and on the bottom is the Nichia 083 (on high):
Here the NS6L183 is on the left:
One at a time:
Ambient:
Nichia 083:
Nichia NSL183:
Here the NSL183 is on the left:
Once it gets darker here in Texas I will add a few more beamshots.
Will
One at a time:
Ambient:
Nichia 083:
Nichia NSL183:
Will
