Nite
I Just discovered that the last time I saw my AA Jetbeam 1 MK IBS was 48 hours ago, when I played tennis and used it to find the balls after it got dark.. Its my favorite EDC Backup, it fit in my pocket nicely.
IM hoping it'll turn up but if I lost it outside the house no one is going to turn it into lost n found.
I recently got Version3 of this for a Customer, a corrections officer, she loves it, but its quite a bit larger than the original. I Dont like it as much as the one I had, as its bigger. However it is improved in other areas. Like runtime and brightness.
Im going to post on WTB on BST at CPFM, hoping to find a used one in good condition, but in the meantime id like to purchase a replacement for it.
heres the specs on the light I lost
pics and details , the review here
https://www.candlepowerforums.com/threads/194877
Jet-I MK IBS Build/Runtime Comparison:
(hoping to get something like this)
Specification: (according to the Manufacturer)
LED: CREE 7090 XR-E (Q5 bin)
Max Output: 225 Lumens ("Torch Lumens")
Reflector: OP aluminum reflector
Lens: Sapphire crystal
Material: T6061 T6 aircraft aluminum alloy
Finish: HA III Military grade hard anodized
Battery: one AA battery or any other batteries of the same size
Input voltage: 0.7-4.2V
Switch: Reverse push button switch
Waterproof: Accord to IPX-8 standard
Dimension: Bezel diameter 21mm, Tail diameter 20mm, Overall length 91mm
Weight: 40g
heres runtime for the version 3 its longer by 9mm and its 20% heavier (10 grams more) Considering i just switched to lithium AA from AW14500P for a weight reduction in summer, 10 grams is alot.
Output & Runtime:
AA Battery
Max Output: 145 Lumens, lasting for 70 minutes;
Minimum Output: 2 Lumens, lasting for 50 hours;
Rechargeable lithium Battery
Max output: 240 lumens, lasting for 45 minutes; (the version 1 is only 225 for 30 minutes but still, smaller and lighter.).
Minimum Output: 2 lumens, lasting for 60 hours
I really liked the AA or 14500 voltage range and higher brightness with 14500, or lighter with lithium AA. It also had 3 Presets with memory. Infinite brightness settings, all from the one button.
I will keep you posted if I find it. I tried to find a smaller Jetbeam, I did, but its not as bright as it doesn't take 14500 I guess..
Im hoping you guys can help me find a suitable replacement in this AA size. Im not an expert on LED lights
I see a jetbeam that uses both AA and CR123, I dont yet know if it can use 14500 or RCR123 as I dont yet know its voltage range.
theres optional reflectors for version 3 as well. I really liked version 1 simplicity. Im going to order V3 from bugoutgear.com perhaps, or something else for "in the meantime"
thanks for any advice on a AA light like mine, or finding the same one...
Weight: 40g
Output & Runtime:
AA Battery
