SmurfTacular
Please see this video.
http://www.youtube.com/watch?v=du3HDv3e5A8
Sorry the video is so short, I took it with my phone and I can only send videos if they are a certain length.
Anyway, I bought five of these drivers because the max input is 15 volts, and for ~$12 its a good deal. I usually use CPF member Download's 7135 driver's for most of my Maglite upgrades, but they only have a max voltage input of only 6 volts, and I need some drivers that can handle >6v for my customers with 5D and 6D Maglites.
So this is the first time I used this driver (even though I bought five of them). And I installed it into a 6D Maglite running six D cell alkalines.; about ~9 volts. So I made the correct soldering contacts between the driver, P7, and the Mag switch. So I fired it up to test out the new driver. I began cycling though modes, thats when I noticed when it is on high mode it will strobe for a second then switch to the low mode. Then a few seconds later switch back to high mode, then strobe and go to low etc... Afterwards I mounted the heatsink in the Maglite shaft to see if that would fix the issue; it didn't
What is causing this to malfunction? does the driver need to be heat sinked?
