can i reverse the cells in my G2 for storage?
KAP
i have a G2Led that im adding to a winter car survival kit. im nervous about leaving the light in the 'lockout' mode because the cap on mine has to be really loose.
can i just flip both cells and tighten the tailcap down and keep it stored like that or will it cause damage to the bulb/drain the cells?
Retinator
Brampton, ON
What about leaving the batteries with opposite ends touching inside, or is that asking for trouble?
Might be best with both (-) ends since there would be a gap between the contacts.
I'm guessing you could tighten down the tailcap all you want then?
I'm no electrical kind of guy aside from testing 9V with my tounge :crazy:
carrot
New York City
Don't do it!!!!!!!!!!!
Leave a piece of gaffers tape covering the end of one battery instead. Or a piece of paper.
PCC
Sitting' on the dock o' The Bay...
That is what I would do. Even if you tighten the tail all the way down the gap separating the two negative ends of the batteries should prevent any problems whatsoever.
