Cornkid
I just ordered a new mountain bike, and I want to build a homemade light system. I was thinking about making the housing out of carbon fiber, and using TIR optics to get a clean beam pattern.
Some other ideas:
For the Front Unit:
- 3 x 1W LEDs, or 1 x 3W LED (CREEs?)
- Finned heat sink
- 2000mAh lithium ion battery (3 or 5V)
- Switching buck circuitry to keep constant current to the LED/LEDs
- Barrel connector for Li-Ion charging
- Simple push-button switch
Rear Unit:
- Two high-output RGB LEDs
- 1000mAh lithium ion battery (3 or 5V)
- Switching buck circuitry to keep constant current to LEDs
- Barrel Connector for Li-Ion charging
- 3 10k potentiometers to adjust Red, Blue, and Green Value
- 1 10k potentiometer to adjust frequency of LED (for blinking Rear Light)
- microcontroller? (Analog may take up to much space)
Any ideas? Any recommended buck drivers / leds? Any good sources for components. (Like LEDs, Drivers, Heat Sinks, Carbon Fiber, Optics)?
Some other ideas:
For the Front Unit:
- Finned heat sink
Rear Unit:
