alanhuth,
If you happen to get a second with a dim LED, it's probably worth it. Don't bother with a LSH-P though because you'll probably get a very small increase in brightness, not to mention you void the warranty.
This is a mod that can be done by someone skilled with a soldering iron and a needlenose (as well as patience). I highly recommend getting a second and trying it yourself. The pride of being able to say "I did it" is worth a lot more than the $$ value you can attach to the light itself. If you are truly all thumbs, then PM me, or Blue Shift if he's willing.
CM
