THere's another point of view: when it comes to raw performance, it's hands down to the Fenix E21. However, there's much more to a flashlight than just lumens, especially when considering it to be an illumination tool, rather than a toy or hobby.
The Maglite 2AA has a longer runtime on high than the Fenix E21 on low, that's 69 lumens for 18 hours from the Maglite and 48 lumens from the E21 for 11 hours, and the 25% low mode on the Maglite will give you 17 lumens for 31 hours. In addition, the Maglite makes a great emergency light because with the candle mode, you can unscrew the head and place the light in the head to use as an area light.
Finally, the Maglite has a lifetime warranty and is assembled in the US, so if anything happens (including battery leakage, they have agreements with the major battery manufacturers to provide service), you can send it back to Maglite in Ontario, CA for repair or replacement. With the Fenix, it's a 2-year warranty and you have to send it back to China. Two years is pretty short for any well-built tool, plus, it will need to be sent internationally for service.
I own several Maglite 2AA LED's, and I've given several away as gifts. Its ease of use and peace-of-mind from the lifetime warranty makes me not hesitate to recommend.
T
I trust the Fenix not to fail-I've had both my mini-maglite 2aa's fail and not bothered to send them back to ontario. The overall "feel" of the fenix is better-clicky switch, glass lens, hard anodization.... metal reflector... and Ceiling bounce illuminates without blinding yourself like a maglite.
I actually prefer plastic windows, as they are unbreakable (if they have an anti-scratch coating, even better). If you want glass, you can easily swap it out. I have an XL100 with a glass window, and I am much more worried about dropping it than my XL50, which has the stock plastic.Yes, Chinese lights such as Fenix feel well engineered, whereas the Maglite is okay, but somewhat crude in comparison, with a plastic lens, and coarse threads.
Maglite specs are all ANSI FL1 with alkaline batteries, so it's OTF until 10%.The Fenix figures are ANSI FL1. The Maglite might claim 69 lumens for 18 hours, but I suspect that is emitter lumens, and what does the 18 hours mean? What batteries are those figured tested with? It makes a big difference.
Sellers never handle warranty issues. Dealers might, but chances are, they will send it back for you. It's a manufacturer warranty, so it's an agreement between the manufacturer and the consumer.And if a light fails, you send it back to the seller, and it is replaced. You don't send it back to China.
Incandescents are much more reliable in that sense, but electronics don't last forever. Generally, issues because of quality control or manufacturing defects don't show up for a while. A good example of this is consumer laptops, which come with a standard one-year warranty (sometimes shorter) where it's quite interesting how most issues occur right after the warranty expires.How many lights fail in use? Very few is my guess. Problems would normally be apparent straight away, in which case the seller handles the return. And if it does fail in use it is usually user error e.g. inserting batteries the wrong way round.
The beam is indeed awful in beamshots, but it really doesn't affect practical use (other than on white walls, where can you see beam artifacts?).To be fair the Maglite is decent for the price despite the awful beam
Flashlights should be built to last, and the gripe I have with short warranties is that the manufacturer clearly doesn't have much confidence in their product, which is why I insist on lifetime warranties.
Really? I broke one putting the reflector back in place, so I've been quite cautious since...but yes, plastic scratches too easily. After seeing Streamlight's anti-scratch plastic windows, I think that's actually a pretty good solution to this problem...unbreakable and unscratchable.Glass is pretty much unbreakable in normal lights-I've smashed them hard enough. Plastic gets craptastic from using a cloth to wipe it.
With these thoughts, I would recommend the Fenix LD25. It has some excellent all around modes and it is built well and the pricepoint is right at $50. Some other good lights I would consider if I were you would be.Thanks for advice friends
I have budget of 50$ and I thinking buy even LD20.
I need flashlight like all purposes outdoor and indoor, I ride MTB biking and for mountaineering, like EDC, and everything else
I want to have a reliable flashlight for long time
