coachclass
- Joined
- Mar 23, 2011
- Messages
- 109
With all the fancy modes and memory features on LED flashlights, how much parasitic drain do you expect?
I really like the Klarus ST20, but I wonder if the memory feature on the tight bezel mode causes some kind of parasitic drain? Or is the drain so negligible that it doesn't matter?
Or, if there's any engineers out there who might shed some light on how they power the circuits.
I suppose if you could verify that the power circuit is cutoff with the switch off, then that guarantee that the LED head is not draining any power, right? So, I you could do it with a simple multimeter using the resistance measuring mode?
If anyone has a Klarus light and a meter, I'd appreciate the test!
Or, if you take the battery out and then put it back in, does it remember the last mode when bezel is tight?
