Hello all, long time lurking - first time posting .
I plan to buy AA powered headlamp from Zebralight. XM-L introduction on the market made it much harder for me - the eternal problem : should I buy now or wait for ZL in H XM-L AA form?
Few times the possibility and gains or lack of them were discussed on cpf, for example here: http://www.candlepowerforums.com/vb/showthread.php?313074-Zebralight-AA-and-XM-L-am-I-dreaming
I decided to combine data from:
http://www.cree.com/products/pdf/XLampXM-L.pdf and
http://www.cree.com/products/pdf/XLampXP-G.pdf
into one graph. Here is the effect om my work:
http://min.us/mvoU5Nx
Because I already had all the data in one spreadsheet it was easy to calculate watts:
Maybe somebody will find it useful. My conclusions (keep in mind that my knowledge about electronic is minimal, I'm looking for confirmation from you):
-Comparing with 200 lm from XP-G it should be possible to get at last 230 lm from XM-L with the same run time or 200lm with 14% more runtime (1.4W vs. 1.6W). Maybe little more - because of lower voltage the losses in the driver should be smaller.
- It's interesting how much energy is wasted in the driver. In theory Eneloop AA has about 8640W (2.0 Wh *1.2V * 3600s) at 200 lumens XP-G uses 1.6 W. In perfect world with 0 loses ZL would lit at 200 lumens for 90 minutes. In real word it works for 54 min. 40% of power is wasted as heat and this is one of the most effective 1AA lights :sigh:
As for me I'm probably going to buy XP-G now. AFAIK there is no leaks about H51 XM-L (H60 AA?) coming soon. The difference in lumens is not that huge at 1AA power levels and I plan to use d-c-fix as a diffuser and have the option of little more throw after removing it. With XM-L it would be the other way and I would have to use fresnel lens or something similar for throw when needed.
What do you think guys?
