hi, this is my f1rst post here
I'm pretty new to all this flashlight stuff, but I own few cheaper lights from DX (with XML and P7) and I've got a pretty good expirience with electronics
I'm building my first from-scratch build, I'll be using this reflector:
http://www.dealextreme.com/p/alumin...or-cree-mc-e-led-emitters-52-15-27-15mm-39409
and some 1A driver board for the LED, it will be powered with 2x 14500 LiIon's. I'm building it inside a 50mm PVC pipe (100% waterproof :devil
well and the question is, which LED will give me more throw? XR-E R2 or XP-G R51B? I'd prefer to use the xp-g because it's brighter, but will it be a thrower?
thanks for advice
I just used that reflector for a maglite build with an xm-l, it worked out really well. The only problem was mounting the led (I used the copper base star model from dx). I had to grind out the underside of the reflector with a dremel and use flat desoldering braid for the leads in order to keep them from shorting on the aluminum. You could use a plastic ring to isolate the leads, but the led will be further away from the ideal focal point.
I would go with the XP-G, but that's because I like the higher total light output and increased efficiency. I think if you want a dedicated thrower, the XR-E will work much better, not to mention that due to the design, it will probably fit a lot better in the reflector designed for the MC-E.
The little ring (should) fit right into the hole, and due to it's increased height over a standard led dome, you will probably have way fewer problems with a plastic isolating ring or whatever else you come up with.
I used the P7 model, but I'm guessing it's similar, and one other thing you'll want to watch out for is the distance between the back of the reflector and the base of the brass ring that screws in. The star I used dropped right down into the brass piece, but when fully tightened, it would just flop around, probably about 3mm away from where I wanted it. I had to make an aluminum slug to fill in the gap. A larger star MAY sit on top of the threaded area and fit in perfectly, and there are plenty of threads to accomodate that situation.
The star I used was 18mm. I would give you the exact dimensions of the other mating parts, but the light has already been given to my brother in law.
