Death's Head
- Joined
- Jun 27, 2006
- Messages
- 305
I have one coming in, and would love to have one.
Please help a brotha out.
I have some QTC material I've been experimenting with. It's harder than you think to work with. You really have to perfect the thickness for you application or else the resistance drops too quickly and you're ramping from full to almost zero resistance in an eighth of a rotation of your light. That requires way too much dexterity when you're trying to be precise with selecting your output.
Consequently, I think one would need to design elements of their light specifically for use of the QTC material. Retrofitting an existing light with the material (which is primarily what I have been experimenting with) is no easy task. Maybe try to sell your Eiger in the marketplace and just order a QTC enabled Eiger when Peak gets around to selling them.
EDIT I just stumbled upon another thread where you said your Eiger was the one with the momentary switch. I don'y know if Peak will be making the momentary lights with the QTC pill. I didn't even know they made any with the momentary switch besides the titanium model.
You can get QTCs from the Marketplace.
They start off as a thin rubber sheet that is cut into squares. They measure about 4mm X 4mm X 0.5mm. I don't think that he means that the thickness needs to be trimmed or anything. I think he's implying that you need fine threads to have finer control over the ramping. Someone with access to a lathe or finer thread taps and dies can probably make something that would work well with QTCs. Also, whatever you do you need to ensure that you don't put any kind of load on the QTC other than compression loads as anything other than compression loads will cause them to disintegrate. Also, the design needs to be such that the QTC can be removed and replaced as they do wear out from use, about 1000 cycles.
SO you mean that you dont want the QTC pill to suffer from rotational forces for example? Only a force pressing straight down?
