gcbryan
I've looked at a few headlamps in the store but that doesn't tell you much. I have a few flashlights and I know what those beams are like as a way of comparison.
I have a P60 XR-E flashlight that has a tight hotspot along with a circle of flood. I bought some cheap TIR optics from DX and replaced the reflector in one of my XR-E lights just for fun.
My initial impression was that it didn't change a thing but upon closer inspection it actually had a more diffused outer edge to the spill so you didn't have that annoying outer halo movement in your periphery at night. You still had spill but the outer edge was just more diffused as it moved from spill to dark.
This would be my choice of beam for a headlamps spot beam. These optics were only about a dollar each. Obviously they would cost much less for a headlamp manufacturer. Why they always have the worst optics I don't know.
As it is most of the smaller headlamps don't use reflectors or optics that are decent. Most (or a least many) just have a distracting look to them. I'm not the only one who has put a piece of scotch (translucent) tape over the optic.
The flood beams on headlamps are usually pretty good especially when separate emitters are used (as opposed to diffusers).
For those of you who use headlamps for hiking at night in the woods what type of beam do you prefer for the spot beam. One that is a bit diffused but throws without a defined hotspot to 75 feet or so or one with a hotspot and larger spill and throws to 200 feet?
In the woods I don't think I generally need to see ahead 200 feet. Sometimes I can't anyway due to the terrain. I haven't had the chance to take my headlamp out this year under those conditions so I'd like to hear others preferences.
I think the Tikka XP 2 has a spot beam and the EOS does as well and it think it's now a bit more diffused that it used to be. The EOS doesn't have a separate flood mode and the XP 2 has a flip down diffuser.
My current headlamp has a flood mode and a spot mode but the spot was with an optic and had an ugly beam pattern so it currently has tape over it making it a diffused "throwing" beam. What am I giving up by the combination? Any of you mountain hikers really need a 200 foot throwing spot? Do you like the XP 2 as and example of spot beam pattern, EOS or something else. If something else please describe the spot beam pattern.
