As an aside: Although it is the scope of the claims that is important in patent law, does this sound familiar?
United States Patent 6,386,730
Matthews May 14, 2002
Dual reflector, rechargeable, and crash-secured flashlights
Abstract
A flashlight having a flashlight head with two merged yet independent lamp/reflector systems, the head including a common reflector structure having two reflectors of differing light projecting characteristics, the two reflectors arranged side by side with a common boundary across part of the common reflector structure. A flashlight holder and battery charger includes interacting surfaces on the flashlight and the holder that permit insertion of the flashlight into the holder only when the flashlight is in a predetermined position relative to the holder, require that the flashlight be manually moved or rotated in a predetermined direction after insertion for locking the flashlight in the holder and for permitting battery charging only when the flashlight's lamps are disconnected from the batteries, and require that the flashlight be manually moved or rotated in the opposite direction for permitting removal of the flashlight from the holder. A sequential switching arrangement on the flashlight changes the light output of the dual lamp flashlight according to the distance by which a push-button on the flashlight is depressed.
Series Code: 10
Filed: May 29, 2002
And what about this for a future accessory for the e series? (This is from an application still pending in the Patent Office.)
United States Patent Application 20020154500
Kind Code A1
Matthews, John W. October 24, 2002
Flashlight securement systems
Abstract
Apparatus and methods directed to a hand holdable flashlight including a battery housing having an undercut groove to which is removably fitted a head of an interface device which itself is removably securable to the object.
Inventors: Matthews, John W.; (Newport Beach, CA)
Assignee Name and Adress: SUREFIRE, LLC
Serial No.: 159359
Series Code: 10
Filed: May 29, 2002
You can see the images associated with these and all of SF's issued patents at the
www.uspto.gov site.
