"better deal" is highly subjective. RRT-0 costs about 50% more with the AA extender. Here are some main differences:
1. cont-adj-brightness vs 3 modes IBS
2. forward vs reverse clicky
3. AA, 123, 14500 battery vs AA, 14500
4. 255 lumens on S2 version vs 240 lumens
5. both roughly the same size, although the rrt0 might be a tiny bit longer with the AA extender installed
The RRT-0 also has strobe and SOS accessible without needing to sacrifice an IBS "slot" that could otherwise be used to store a brightness setting. I don't remember if the Jet-I has an SOS option, but if it does, then to have strobe and SOS available on a Jet-I you would be left with a single "normal" brightness setting. With the RRT-0 you can have all possible settings accessible within 1 second or so, no programming required.
One must evaluate whether they want to pay extra 50% for rrt-0 vs jet-i pro. The con-adj-brightness is what I perceive as the biggest difference but personally, I won't pay extra 50% just for that feature. IBS is still programmable and 3 settable brightness level is sufficient for me.
Have you tried a continuously-adjustable light with a control ring? If you haven't, you can't possibly assess whether you would prefer it vs. a multi-click light.
I don't care for forward clicky on an AA size light.
Care to provide a reason for this preference? Remember, you don't need to multi-click the switch on the RRT-0 to change modes, so a reverse-clicky's main benefit of allowing mode-changes without turning the light off is irrelevant. Meanwhile, the forward-clicky allows you to blink the light very quickly without having to latch and un-latch the switch.
I don't have 123 batteries and 14500 provides the same brightness. I cannot visually tell between 255 vs 240 lumens. Since I don't have 123 battery, I run AA or 14500 so smaller is better.
According to the Jetbeam website, the length of the Jet-I is 100mm and the length of the RRT-0 is 97mm. Since 14500 batteries are 16mm longer than 16340 batteries, that means the RRT-0 with the 14500 extender is 13mm longer than the Jet-I. That's half an inch. That's not a significant increase in length for a light that's less than 4 inches long to start with.
Yes, but the RRT-0 with the extender is just about the same size as my Jet-3 Pro ST using an 18650! If I had to choose between throw and run-time (and the Pro ST throws pretty darn well), in general, I'll take the run-time.
The RRT-0 with the 14500 extender is 7mm shorter than the Jet-III Pro ST, which I agree isn't much. It's also the same width at its widest point. However, the RRT-0 has a pocket clip to keep it out of the bottom of your pocket, which the Jet-III Pro ST doesn't have; all of its battery options are lighter and less expensive than an RCR18650; and it has the continuously-adjustable brightness feature, whereas the Jet-III Pro ST has only three modes. So while it's a comparable size, it's not a comparable package. Maybe the Jet-III Pro ST throws further, maybe it doesn't -- I suspect the reflectors are comparable though, since the heads are the same width.
I personally would like to see them move to an XML like they've done with the Jet-3M, and use a deeper reflector to focus the light more for more throw, but that's just me. (And make a neutral version available as well.)
The XM-L wouldn't be a good fit for the RRT-0, in my opinion. While the head could hold it and the battery couldn't possibly drive the XM-L hard enough to produce excessive heat, the XM-L emitter die is much larger than the XP-G emitter die and would require a proportionally larger reflector to focus it the same as the current model. You say you want throw, well, the XP-G is much better at throwing than the XM-L is. The XP-G is still the best Cree-brand emitter for small flashlights at this point.
I will agree that if Jetbeam upgrade the Jet-I to XML AND redesign the reflector to keep it a throw light, I will also be all over it and trade out my R2. However, if they redesign and give it a deeper reflector to keep the throw, that also mean they have to redesign the head. Without modifying the head, I am not sure they have room to put a deep disk reflector in.
Yes. Using the XM-L would require a driver tuned to its performance characteristics, and the wider emitter die would require a deeper reflector, which in-turn would require a redesigned head. At that point it's basically a whole new flashlight, because the head is where all the technology is. The switch and the battery tube are nothing by comparison. So if they're going to redesign the light, they might as well upgrade the interface too, which they did -- that's what the RRT-0 is; it's the Jet-I and the Jet-II rolled together with an upgraded UI.
