nukeiridium
- Joined
- Sep 30, 2003
- Messages
- 6
Hi everyone, I'm new to using LED's in general. What I did is purchased 6 of the following UV LED's:
http://www.superbrightleds.com/leds/uv_specs.htm
I then took a Mag Lite that uses 6 D cell batteries, took an extra bulb, broke it, and soldered the 6 LED's in a pattern like this on the end of the bulb: (view from looking into face of flashlight)
[image]http://cleedo.com/leds.bmp[/image]
Then I put it all together. It shines really bright UV light and I tried using it for scorpion hunting. It works great so far and I can see scorpions glowing green from like 15 feet away.
Now, my question is, shouldn't this burn the LED's out? I'm running them at 4.5 volts when their max is supposed to be 4 volts. I have no idea what Ma the batteries are because the damn things don't say anywhere on them. They are fresh batteries. So far I have used the light for approximately 4 hours straight without any noticeable change in brightness or color.
Why does this work? Is it just going the make the LED's not last very long? I took the lens off while the light was still on and had been in use for 30 minutes or so and the LED's were not warm.
Please tell me what you think. Sorry about my ignorance in this area, I'm just curious about this particular project.
