So I did some un-official tests as I have quite a few Malkoff modules on hand to play with; I tried the following combinations:
M60 + 16340
M60LF + 16340/primary
M60LL + 16340/primary
M30F + 16340/primary
M61 +16340
M61L + 16340/primary
M61LL + 16340/primary
M31LL + Primary
I was looking for the best split between output and versatility. Again, this was by eye only, no equipment, but I was able to do side by side comparisons witht the same setup as I have multiple VME heads and L1's as well.
Without fail, the M6X series lights were brighter with the 16340 and certainly more flexible as they could use RCRs and pirmaries, same with the M30F.
First observation: The IMR was brighter on both high and low for all drop ins, no surprise
Second: All drop ins lit on both high and low with a single primary, again, no surprsie
Third, and this was a surprise, Universally, when using an IMR, the split between the low and high mode was not as great as when using a primary. In other words, the nice low low was gone and became much brighter than what I would prefer in the L1
That said, the one combination that did work the way I expected was the M31LL. It had the beam profile I wanted and, more importantly, the high/low split was great... nice low low and very avery good full output high ON A PRIMARY...
I opted not to use any of the M60 series lights as the beam profile was too cloise to the stock L1 and I did not see the benefit, whereas the F modules and the M61/31 series lights had a very nice profile depending on the need.
It's M31LL for me in this setup, going to see what I can do about informal runtimes next
D
