Hey all, I'm new here and found this template to be pretty handy. I'm looking for a decent edc flashlight that uses durable and reliable technology and also is as bright as can be. Check out the checklist I put together. Some of the lights I have been looking into include the 4sevens Preon 2 (really like this after Nutnfancy review), Fenix Pd20 and Ld05, LD15 (don't like the twist ui). So is there any others I should look into? Also, is there any guides on here that can give me an introduction to new flashlight technologies? I am still kinda new to quality lights.
I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Other, please specify $45 - $85
3) Format:
I want a flashlight.
4) Flashlight-specific format/size:
Keychain size.
Every day carry small (2-4 inches).
5) Emitter/Light source:
__x__LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
__x__I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
__x__I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). (although I doubt I can find one in the price range)
7) What battery type do you want to use?
__x_I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
__x__I want to walk around an unlit rural area plus some (50-180 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
_x__Less than 1 yard/meter (reading, other close work)
_x__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
_x__5-20 yards/meters (check out a noise in the backyard)
_x__30-50 yards/meters (I have a big backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
_x__30-60 minutes (I have plenty of batteries just ready to be changed)
__x__Very Important (Camping, Backpacking, Car Glove-box).
12) Switch Type and location (choose all that apply):
__x__I want a tail mounted switch (found on the majority of today's high end lights).
_x__I want multiple light levels. (Some lights have 5-16 light levels.)
_x__I want a strobe mode. (Blinks to show location.)
_x__I want SOS mode.
_x__I want a beacon mode.
14)Material/Finish/Coating
__x__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
__x__Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
__x__Pocket/belt clip
3) Format:
Keychain size.
6) Manufacturer:
