got my new olight i3 yesterday... just a quick visual comparison of the two for those interested...
itp a3 eos on left, new olight i3 on the right
first thing you notice is that the i3 is a few mm longer in the back... this is to accommodate the new clip and so that it can tail stand. no big deal, picture makes it look bigger than it actually is...
I do feel however that they could have implemented the keyring a little better.... if you look at the picture above, notice the angle that the keyring sticks out at... well there is very little movement from this position.. just a few mm of play in either direction... you cant make it stick straight out the back like the a3 eos on the left is almost doing..... this makes it sit on a keychain kinda wierd... they should have just made the two extra little cuts like they did for the illuminati and it would still tailstand and be damn near perfect:
as far as physical robustness... for some reason this little i3 feels better built than its itp a3 brother... my a3 had a little play in the head and would allow you to do the thing where if the head is almost turned on, you could push the whole head assembly towards the body and it would temporarily turn the light on... they must have done some tighter tolerances with the threads on the i3 because now you have to have the head really really close to being on in order for this to happen... the twisty operation feels a LOT smoother than my a3 as well... no stiffness or grittyness at all...
the light has a new clip system built in that uses two tiny allen head screws (comes with the proper wrench) to hold it on.. this clip is TIGHT on there.. almost couldnt get it over a normal jeans pocket... thats a good thing right? i havent taken the clip off yet so i cant give any reviews on ease of removal or anything..
the reflectors are virtually identical and have the same XP-G R5 inside...
with two new energizer ultimate lithiums from two feet away on high:
pretty much identical here as well. tint appeared almost exactly the same.
im not going to do runtime tests, ill leave that to someone else... i was almost to busy to do this post in the first place.
