Hi CPF,
I need help choosing a light for someone.
I emailed him the "checklist" and here's what I got back.
I do have suggestions of my own, but, I'd rather him see suggestions from others also...
Please help him get the most bang for his buck/needs.
EITHER WAY, SOONER THE BETTER. I NEED SOMETHING STRONG FOR HUNTING AND SHOWING OFF A BUDDY.
_X___I would like to purchase the light from a brick and mortar store. I am located in ______________.
_X__I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest!
____Less than $25.
____Less than $50.
____Less than $100.
_X__Less than $150.
____Less than $300.
____I have no limit.
____I'm flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
_X__I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
DOESN'T HAVE TO HAVE A HOLSTER, BUT WOULD BE NICE.
____Keychain size.
____Every day carry small (2-4 inches).
__X__Every day carry medium (4-7 inches).
__X__Holster carry.
____Big enough to need its own travel caseJ.
____I don't care.
____I don't know.
____N/A
5) Emitter/Light source: I HAVE THE STREAMLIGHT TRL-1. I THINK THAT IS LED. I WANT BRIGHTER WITH MORE THROW AND FOCUS FOR HUNTING AND SPOTTING AT LONG DISTANCES.
___X_LED (known for efficiency, longevity, and compactness)
_X___I don't know.
6) Manufacturer: DOESN'T MATTER, I DON'T WANT TO GO TO FAR OVERBOARD WITH THIS. (I TYPICALLY DO WITH MOST PROJECTS)
_X___I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
_X___I would consider getting a light that is pieced together (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use? I REALLY ONLY WANT TO USE THE 123A BECAUSE MOST LIGHTS THAT USE THIS POWER CELL ARE STRONG, I COULD BE WRONG THOUGH. He's open to Li Ion/18650... I let him know of the "dangers", seems comfortable with it. I was going to suggest Nimh/eneloops(TK41/40) before I received this checklist back..
____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today's most powerful lights)
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
_X__I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
_X___I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
_X___I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
_X___I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
__X__150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
I DON'T WANT TO HAVE TO BUY BATTERIES EVERY TIME I GO HUNTING, BUT THE LIGHT WILL NOT BE ON ALL THE TIME.
____30-60 minutes (I have plenty of batteries just ready to be changed)
_X__90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
_X___Slightly Important (Walks around the neighborhood).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don't know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
_X__I want a tail mounted switch (found on the majority of today's high end lights).
____I don't care.
____I don't know.
TEMPORARY SWITCH IS NICE, LIKE ON THE TRL-1. THERE IS A CONSTANT AND A TEMP, BUT SIMPLE ON/OFF WOULD WORK. STROBE WOULD BE NICE, BUT NOT A NECCESSITY AT ALL.
_X___A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
_X___I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don't care.
____I don't know.
14)Material/Finish/Coating
NOT PLASTIC BUT WEIGHT IS NOT A HUGE ISSUE.
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's flashlights).
__X__Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
NOT A MUST HAVE, BUT WOULD BE VERY VERY HELPFUL TO HAVE A GREEN REMOVABLE FILTER
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
_??_Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
My edits/notes/suggestions are in red.
Any comments/suggestions appreciated.
Thanks
____Less than $25.
____Less than $50.
____Less than $100.
_X__Less than $150.
____Less than $300.
3) Format:
____Keychain size.
__X__Holster carry.
____I don't care.
____I don't know.
____N/A
_X___I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____I don't care.
____I don't know.
____Holster
Thanks
