Hi!:twothumbs I need help creating an off-road led light like the vision-x/rigid industries lights. This is for a dual sport bike for high speed desert riding. I just wrote a really nice post and I got kicked off before I posted it, so forgive me if this has errors. Hopefully I can get some good ideas/help from you guys, I can't believe all the knowledge hidden on this sight, if I only had time to read it all!!!!!
I have been reading a lot, and haven't found enough specific information on what I need. I am also quite confused about the heat dissipation/cooling of LED lights. So I take it I need to make a heat sink to mount the lights to, but this will be inside a case correct? Do I use something to transfer the heat from that to the case? I see cooling fins on a lot of cases, it's a good idea to machine them into my case correct? I also don't understand how much cooling is needed for different amounts of power draw? (I haven't gotten to thermodynamics in school yet ha!) I mean like...is it linear, and is increased cooling made possible by larger heat sink/more metal for the whole light?
I don't know of 1 or 2 lights would work better for this type of usage? I could possible have 2 lights and mount one on each side of the handlebars or one on each fork. I thought this might be better, I could have a spot and a flood light and adjust them separately? I was hoping to keep them sort of small, but I'll make whatever it takes to last and dissipate the heat. I was thinking under 3" diameter or square each. If they need to be larger I would rather make 2 then 1 light so they stay smaller.
I also don't really know much about optics/reflector size. I think I've read small die+small reflector=more throw, but you are losing total light output for this? I would like a lot of light and throw, so I am not sure exactly what to do for reflectors. Also, are special lenses needed? Or is just clear glass going to be the best bet, and let the reflectors focus the light? I've seen some of these bike lights with what looked to be tiny reflectors really throw some light, so maybe you don't need as big as I think. Would an aspherical lens on the spot beam help, or is that a terrible idea?
I like the specs I see on the cree xm-l, but I thought that doesn't throw as well as a XPG, or is the difference minimal because of the greater lumen output? For drivers 1 mode is fine, but I wouldn't mind 2 if possible. Sometimes when really dusty it's better to have less light so you don't blind yourself. I don't know what I would need lumen wise? Would 3-4000 do what I want? Or is that way overkill and not possible in these size lights?I need help coming up with some ideas, then I will CAD it up and machine it. I just want to understand more of these things before I waste money ordering parts that won't do what I want. I am a college student on a limited budget , so hopefully what I want out of this is doable. I guess I could increase the budget if I need to, no point in spending 100 if it won't do what I need.
What I need:
-Good lighting at 150+ meters for high speed riding, but still need flood, can't just be 5 feet wide at 300 feet lol!
-Need help choosing reflector, LED, driver, lens, etc.
-Hopefully under $100 total minus metal to build case (I have a lot of scrap 6061)
-I have lathe, mill, indexer for mill, bunch of other machine shop items, so I can machine just about anything (No CNC access unless absolutely needed)
-Hopefully less than 5 amps draw at 12.5-13 volts (Voltage under load depending on RPM)
-Water Proof/Resistant? Need to work when riding in rain, can't quit working when muddy/wet, but not going to be taking underwater/diving.
-Vibration/bump proof! (Damn thumpers really vibrate, I've killed a GPS from the vibes.)
-1-2 lights (spot and flood maybe?) with max size of 3ish inches diameter/square by a 3ish inches long maybe increase the size if absolutely needed
Thanks so much for any possible help. I know it is a long winded post, but hopefully I got all the info down and all my questions! I have so much to learn, but I am so busy with class and work, so hopefully you all don't think i am lazy by not reading anymore. I have spent hours on end reading here, and I am still lost when it comes to some of these things!
What I need:
