Led Zepellin Heatsink + 4XM-L + FM3H-v2 + Surefire M6 (Petrev 4x18500) + D2Flex
petrev
SW England
LZ- 4XM-L FM3 + M6
4x XM-L Mounted on 12mm (12.8 cut down) MPCB
LZ-M6 Cone adapter with Shark+Ramora (Heatsink needed 2 extra holes to attach cone
M6 to D-Mag Adapter (FM Modified with O-Ring groove, Removal Slots and re-bored to D-Mag inner dimension
Added Reed Switch to operate D2Flex Board (Shark died on me) - 5 Levels, Memory and Turbo
Rubber Ring with Magnet attached to Bezel (Black double sided sticky foam tape 8mm)
Bezel is modified to be straight cut to head (Blue Magnet Marker)
Powered by 4x18500 in a custom carrier with the extra space added using an STC (Short Tail Cup) still available !
LedZeppelin/FM Cousins (LZ 4xP7 in FM Elle2 Custom HA3)
nein166
New York
Nice I was thinking of using a reed switch for a maxflex in a KL2 head but I figured I'd use a magnet on a lanyard.
Your foam tape spins?
petrev
SW England
Hi
The whole bezel spins relative to the head. You are just unscrewing it a bit to activate the reed.
I would like to make a proper ring from a nice black delrin say but I had to do the mod in two days for a get together so . . .
Fun and works for now,
Pete
