Preon 2
Low: 2.2 OTF Lumens, 23 hours
Medium: 22 OTF Lumens, 6 hours
High: 160 OTF Lumens, 0.8 hours
Preon 1
Low: 1.8 OTF Lumens, 23 hours
Medium: 8.5 OTF Lumens, 6 hours
High: 70 OTF Lumens, 0.8 hours
4sevens.com specs are correct.
When recently I got my Preon 1, a quick check of lumens and battery current showed results far from those specs on medium and low so I went looking on the forum.
http://www.candlepowerforums.com/vb...(1xAAA-amp-2xAAA)-RUNTIMES-BEAMSHOTS-and-more!
In Jan 2010, Selfbuilt measured two different Preon 1s and got run times of 2:12 and 2:17. He estimated the output at ~20 lumens.
http://www.candlepowerforums.com/vb/showthread.php?287386-Epic-AAA-Run-time-test-(low-level-only!
In Aug 2010, Beacon of Light measured the Preon 1 run time on low at < 11 hours. It looks like it was checked at 8 hours and out at 11 hours. Another poster reported 11 hours on an Alkaline.
I measured medium at 22 lumens. Low is approx 3.6 lumens and I got less than 9.5 hours run time to off on an Eneloop. It looks like the light takes about 15 minutes from when it drops out of regulation on low to when it goes out with output down to a few tenths of a lumen before it dies.
I won't quibble with the high rating of 70 lumens OTF as I measured 70 lumes initially on a fully charged Eneloop and 78 lumens for a few seconds on an Eneloop hot off the BC-900 fast charge. That said, I suspect the ANSI 3 minute rating would be 60 or less and it spends most of its' unregulated run time in the 45-55 lumen range. (I found a web site still selling the Preon 1 S2 where it was listed at 60 ANSI lumens and the R5 version should be ~7% less.)
Given these huge errors in the Preon 1 specs, I'm not sure I'd buy another 4sevens light without checking here first. That said, I like the Preon 1 although if my ITP EOS A3 didn't have severe contact issues making it unreliable, I wouldn't have replaced it with the Preon 1. I got tired of cleaning it constantly and no amount of cleaning got the output back as high as when I got it even though it was never run on high constantly for more than a couple of minutes. My AAA EDC gets a LOT of use,
many times more than anything else I own.
